jason51873
- Joined
- Feb 9, 2013
- Messages
- 5
- Points
- 0
I need the wifi drivers for the wifi card. Can you please look on your Surface Pro and tell me the model number of the wifi card. Or even better yet send me the drivers?
For future reference even if you formatted the restore should work. It is on a different partition. Even then you can put it on a USB stick just to be sure you have it in case you decide to format that partition too.
