I couldn't understand how some people got 5 hours on the original SP. I could only get around 3.5 on mine. I figured it had to do with the software installed so I wiped it and did some tests. Sure enough, the programs I like to use install all kinds of background processes that suck up battery. Get rid of all the programs that just sit there and check for updates etc. I got rid of things like the VMWare tray process, Nikon Message Center, Adobe Service Manager, WinZip Executable, Send to One Note, etc. Even getting rid of DropBox (I switched to Skydrive) helped.
I travel every week for work so I get to test battery life a lot. I made my first plane trip this week. I loaded up heros of might and magic 5. I am using an external mouse which has a dongle that consumes the single USB slot on the SP2. I have the 256gb 8gb ram version.
I left Rochester NY and landed in Atlanta ~ 2hrs later, battery just about dead.
I'm going to adjust some of the settings I've read about and see if that changes things. I really hope I can get more that ~ 2hrs as I can get that with any laptop. My Lenovo w530 can play heros of might and magic for 2hrs on a single charge.
I'm surprised how many people don't know about the power options.
You guys need to go and create your own power profiles. Especially for those times you're just browsing.
Start with the Power Saver setting. Turn all your settings as low as possible for you to browse. Don't set the max power higher than 50% or you could even go lower. Mine was fine at 30%. My house is mostly dark so I can browse at the lowest setting. Set everything as low as tolerable for what you generally do when you are just browsing. I regularly got readings and use of 6+ hours on my Surface Pro 1.
