It is possible with a poorly shielded cable, the frequency could be interfering with WiFi....Ok. Intersting. What does the Mini Display Port have to do with my network signal though?
ASUS VE228 I sell a ton of them and it works great with my SP4, and they also work well with the dock. 22"Please recommend me a monitor that
- I can use with the Surface 4 dock
- Doesn't have any scaling issues or font blurriness
- Costs between $125-$250
- 22-24 inch size
I remember reading a post within the last one month where he had a problem with bluetooth or wifi on his surface 4. Ultimately, it was due to interference from the lava lamp on his desk!
Suppose you have a web page open in monitor. Then you disconnect the dock and web page is now shown in the tablet. Do the fonts look blurred in this case? Also, what scaling are you using for monitor and tablet?Bought a Dell U2515H, using a mini DP -> DP cable to connect it via the dock. Only problem I have is that it sometimes forget my screen setup when I connect it (only want external monitor active). Otherwise it's golden![]()
