Step Five - Plug and Play will install the Original Drivers (Unless you've ran disk clean-up and removed a bunch of stuff)
Step Six - Adding this as it was pointed out to me, run Windows Update and it will offer the June Updated Drivers (I hid this Update as I didn't want it to install it)
Not sure what he means here: step five, is he saying, let the machine install the original drivers?
Step six: is he saying run windows update and then let it install or do not let it install this update?
Sounds like you have it all under control but just to be clear for others:
step 5: Yes, windows will install the original drivers.
step 6: No, do not install the update. Hide it and forget about it. Installing it would put you right back where you were with the connection issue. MS will eventually issue a new update that will fix the problem.
