I discovered something very weird last night. I was trying to switch my home network over to an Apple Airport Extreme, latest dual-band model with 802.11ac capabilities. However, the wireless speed of the connection between my Surface Pro 2 and the Airport Extreme was being limited. I could connect the Surface to the Airport Extreme wired and would get almost 100Mbps download, but through the wireless 802.11n 5GHz connection only 30Mbps download. I reinstalled my NETGEAR WNDR3700 dual-band wireless router and the Surface was happily getting over 90Mbps download on the wireless 802.11n 5GHz connection. The Surface uses a Marvel AVASTAR 350N chip for its wireless radio, not Intel. But I could not figure out the problem with the wireless connection to the Airport Extreme router, even after an extensive google search. All of my firmware, updates and drivers on the Surface are up to date and so is the Airport Extreme firmware.
Anyone else notice this issue? If so, do you have a solution to settings on the Surface Pro 2 or on the Airport Extreme that will improve the wireless connection speed between the Surface Pro 2 and the Airport Extreme? Otherwise, I will have to go back to my older NETGEAR WNDR3700 router and sell the Airport Extreme.
