Will this MicroSD Card work with my Surface Pro?
TunaSurface
Hello, to keep it short, I've had problems with SD cards with Surface's before, so before buying a new card, I'd like some help from someone smarter than me.
Will this Sandisk 64GB Mobile Ultra microSDXC work with my original Surface pro?
sandisk-64gb-mobile-ultra-microsdxc-class-10-adapter-gtechsolutions-1206-06-GTechSolutions@6.jpg
30 MB/s Transfer speed
Class 10
UHS Speed class 1
IDK
However a "Mobile Ultra" is an older product than the current "Ultra" product with 48mbps speed rating.
What's the difference between mobile ultra and ultra.... nuttin really
http://forums.sandisk.com/t5/Mobile...tra-and-Ultra/m-p/289540/highlight/true#M1911
So you might or might not get a good price on an older product.
Note there is product/packaging decode info in the link above however there may be changes since it was posted.
I couldn't find any info that indicates if there was Android specific software on the card, probably not.
To me unless the price is significantly better than the newer 48mbps Ultra card Id Go with the newer one. Note also that some older 30mbps "Ultra" cards are still for sale also. YMMV.
Sandisk micro SD cards come in several classes worst to best.
Sandisk
Sandisk Ultra
Sandsik Ultra Plus
SanDisk extreme
SanDisk extreme plus
SanDisk extreme pro
Except SanDisk high endurance is a slower 20mbps product for video monitoring (continuous writing).
http://www.sandisk.com/products/memory-cards/microsd/
Class 10
UHS Speed class 1
Hey Tuna, I have that exact same SD card in my SP3, never had a problem with it.
This is it at Amazon... http://amzn.com/B00M55C1I2
