Will SP2 fit in dock with the Capture for SP case on it?
sdgmcdon
I have a need for work for both the dock (to use it as my primary PC as well) and the capture case (the one from I think incipio that also allows you to rotate the device) and wanted to know if anyone has this combination yet and if so, will the dock work without having to remove the case?
Thanks!
I'm rather positive you have to remove the case to dock, judging by how the Pro slides into the dock all nice and snug-like (uh, from pictures, as I don't have one). I imagine the most protection you can have on a docked Pro is a skin.
