WIFI Speed Issue
Rich OReilly
I have the latest firmware (jan) on my SP3 and I am having Wifi Speed Issues.
Marvel Driver= 15.68.3073.151
I noticed this issue when trying to play streams on Youtube.
When comparing my SP3 to my Dell Laptop I get the following results:
I do have a high speed connection at my home.
Same web site both machines=http://speedtest.comcast.net/
Dell LT:
Down = 69.8
Up = 11.68
Ping 14Ms
SP3
Down = 1.42
Up =wont compelete the test Ping 10Ms
Any Ideas as to a fix
kundas1
see if your firmware is upto date on the router, the marvel wifi cards don't like older routers...
RottenMutt
you didn't list your router/access point.
wow a ping of 162 days!!!
i get file transfers of 45 MB/s to my nas using a netgear R8000 router as a access point.
R
Rich OReilly
Router is CISCO xb3 (3939) with latest drivers.
I have the same connection issue at other locations as well, not just at home.
update:
Seems to be just on 2.4 Ghz connection
Ran 2nd test after thinking about it:
I switched the SP3 to 5GHZ
Down = 82.31
Up = 11.59
Ping 16Ms
Then switched to 2.4Ghz (where it was connected before)
Down = .71
Up = wont complete
Ping 11Ms
hmmmmmmm..
I just had noticed my first WiFi speed issue. Normally maxes my 100/5 Internet over 40Mhz channel in 5Ghz band. I was streaming YouTube and walked between access points. My video stopped and WiFi dropped to ~1Mb down. Tried rebooting my access points, toggling Airplane mode, and moving back to the previous access point. In the end, I had to reboot the SP3 to restore normal WiFi speed.
