Wifi Problem not caused by adapter
bennywiggs
One or two days after the last big update I received on my Surface Pro 3, my wifi stopped working. Interestingly, it does not seem to be the Marvell Wifi adapter that is causing the problems. I have tried connecting to my home network and my school network. This is what I have come up with:
1. The Wifi adapter seems to connect to the router, but I see messages like "No Internet Access, Open" or "No Internet Access, Secure" (depending on which network I am attempting).
2. I have tried uninstalling and reinstalling the Marvell device. That did not work.
3. I disabled the Marvell device, and I installed a Linksys USB Wireless Network Adapter. It runs into the same problem on every network I try.
4. I put the Linksys adapter in my desktop, and it connects to the internet just fine.
5. All of my other devices (phones, PS4) have no problem connecting to these networks.
I feel like I have ruled out the network/modem/router. I have also ruled out the wireless adapter because it happens on the surface pro no matter which adapter I use. What else could it be?! Any suggestions?
Oh. One more thing. If I open Edge, Edge locks up. It does not show the standard white screen that says it is not connected. it is just black, and I cannot exit out of it without going through the task manager. Further, I hear the fan really speed up whether or not I have Edge open.
Update the network drivers (Internet needed)
Use the Network troubleshooter.
Reset network adapters.
Perform a registry tweak with Command Prompt.
Change the adapter settings.
Reinstall the network adapter.
Reset your router.
Update the router firmware.
This May Help,
Peter
