Is anybody else having issues where the transmit speeds refuses to go higher than 65MB (max speed for a single spacial stream) I wonder if Microsoft's "fix" was to disable mimo or something. I'm about 10 feet away from the router and I use to be able to pull 130 pretty much all the time or 270-300 on 40MHz. I also have the issue where if I connect a bluetooth device it instantly goes into limited connectivity. I've uninstalled and re installed with no luck. Why, Microsoft, couldn't you give us an Intel card?
