disambiguous1
My wife needed a computer set-up that would allow her to work from home on occasion. She borrowed my Surface 3 Pro to check it out, and liked it. Since it looks like she will be needing a new laptop soon, I set her up with a system based on the Surface Pro 3. I got her the dock and a big monitor.
BTW, she has an original Surface RT, and uses that a lot for email and such.
It took a good couple of hours to set her Surface up with the dock (note to people setting up the dock-- you MUST have the dock attached when you do the SECOND update. You do the first update BEFORE you attach a brand new computer to the dock, then attach the computer to the dock and do the second update. In my case there were 54 updates to perform when it attached to the dock, and it sure looks like there is software/firmware inside the dock itself that is modified).
The problem comes when I try to attach my Surface Pro 3 to the dock. It looks like the dock is "married" to her computer, because when I first attach my computer to the dock and then turn it on, it will NOT accept my password! If I take the computer off the dock and then go through the password sign in, then attach it to the dock, it will work-- mostly work, anyway. There are still a few hiccups.
Does anyone know how to deal with this? Are docks designed to work with only one specific computer? This is kind of nuts. Imagine an office where you have people switching between docking stations. If Microsoft made this computer for business, you'd think they'd consider that. -DA1
