munakib
The trackpad on the touchcover2 was so awful, specially coming from a macbook air, I just couldnt take the harsh surface (pun intended) and finally decided to go alil radical and got myself the magic trackpad by apple. Its a great partner when working from the bed/table. Now, I can have the smooth and specially accurate trackpad at the perfect distance from my hand - scrolling feels like heaven, double tap/single tap, wah, what a life saver. Yes I know it ruins the whole idea of portability but when I am not moving around at work/on meetings, Apple's lil devil can make you be more efficient. I would seriously recommend you give it a try.
You gotta do alil unzipping/to get the trackpad driver from the bootcamp driver installer, you can always google that - use 7zip, its the only application which can unzip the installer to get you the driver file you need.
A special tweak that is a must do is changing/inverting the scrolling so that it feels natural:
1. Find the hardware ID of the mouse
Go to the mouse control panel
Select “Hardware” tab
Click “Properties” button
Select “Details” tab
From the drop-down list choose “Hardware IDs”
Save the VID*** entry ( e.g. VID_045E&PID_0039 )
2. Find and change the corresponding configuration settings in the registry
Run regedit.exe
Open Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\HID
Here you should find an entry for the hardware ID of your mouse
In all sub-keys of the hardware id key look for the “DeviceParameters” key and change the “FlipFlopWheel” value from 0 to 1
3. Make it work
Unplug the mouse
Count to five
Plug the mouse back in
Run regedit.exe
3. Make it work
Unplug the mouse
Count to five
