Sync iTunes to Surface Pro - Transfer iTunes movies to Microsoft Surface Pro
PavtubeVideo
Want to get your movies, TV shows from iTunes ported over to Microsoft Surface Pro tablet for enjoyment but have issues? Simply follow this article to achieve your goal smoothly.
As we know, movies, video, TV shows purchased from iTunes stores are locked with Apple's DRM protection. You can only play the media on Apple products like iPhone, iPad, iPod, etc. If you own a Microsoft Surface Pro, you must want to watch the iTunes movies on it since Surface Pro is an outstanding portable digital media player with its 10.6-inch, 1,920 x 1,080 display. However, due to DRM protection, even if you can transfer iTunes movies to Microsoft Surface Pro, you cannot watch them. However, the good news is that there is still a way to play iTunes M4V videos on Surface Pro for Windows 8 tablet by removing DRM protection from iTunes movies and convert M4V to Surface MP4. To ahieve your goal smoothly, below is a simple tutorial for you, guaranteed to get iTunes movies and Microsoft Surface Pro to play nicely.
To get the work done, you have to download an app that you are going to use later. You are recommended to download and install:
ChewTune (available for Windows or for Mac users). Get the Windows version here, and the Mac version here.
The program is an intuitive and stable iTunes Movie DRM converter which can easily handle DRM-protected contents including iTunes, Digital Copies coming with Blu-ray/DVD discs and more. Meanwhile the playback of the converted videos is as decent as possible as original. Just get right version and follow the step-by-step guide below to learn how to put and play iTunes purchased movies on Microsoft Surface Pro without restrictions!
How to Convert DRMed iTunes M4V to Surface Pro DRM-free MP4 videos
Note: This guide uses ChewTune for Windows screenshots. The way encoding iTunes to Surface Pro on Mac is almost the same.
Step 1. Run the iTunes to Surface Converter and click "Add Video" or just drag & drop to import your iTunes files (movies or TV shows) to the program.
Step 2. Choose the output video format and output folder. Click "Format" bar and move mouse to "Windows" column, you can easily find the profile of "Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)". The output videos could fit on Surface Pro or RT perfectly.
If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish. P.S. For watching videos on the Surface Pro Tablet, 720p with 1500~2500kbps is just all right. I find that bitrate higher results in big file size, and lower visible quality loss.
Step 3. After above steps, just click "Convert" to start removing iTunes DRM protection and converting iTunes M4V to Microsoft Surface Pro MP4 videos.
As you see, once the process completes, download and transfer the DRM-free iTunes videos to your Surface Pro Tablet via USB cable and enjoy the movies.
Plus, if your movie isn't already in one of the supported formats or it's still on a DVD or a Blu-ray, you can get the Blu-ray Video Converter Ultimate (or the iMedia Converter Mac)which can help you rip Blu-ray/DVD, and convert various formats of 720p/1080p HD videos in MKV, AVI, TiVo, VOB, MPG, MTS, etc. to your Archos tablets and other Android/iOS/Windows RT (8) based tablets/phones for smoothly playing.
Remove DRM from iTunes M4V and Sync iTunes library to Surface RT and Pro
This article will show you how to get music, movies or TV-shows purchased from iTunes to Microsoft Surface RT for smoothly playing.
Q: I just bought a new Surface tablet and I am wondering if I could play music files I purchased on iTunes on my Surface RT? I have searched around the internet but I haven't got a specific answer to this question. Besides, the movies and TV-shows I have purchased on iTunes will be playable on my Surface RT?
A: Before answering your question, keep in mind that the Windows RT based Surface tablet can not play any iTunes purchases with Apple Digital Rights Management (FairPlay DRM). However, all iTunes songs (at least in the US) will be DRM-free in steps since April 7, 2009. From my experience, if the song isn't copy protected it should play. For the little copyrighted iTunes songs, in .m4p format, you can upgrade these songs to DRM-free files for US$0.30/song or use DRM removal software to strip DRM from them free of charge.
For iTunes videos, if they are video podcasts from iTunes, you can play them on your Surface RT without any problem. But if they are Movies, TV-shows or Music videos which you purchased directly through iTunes store, they are all with DRM protection. DRM can not stop you transferring iTunes video purchases to Surface RT, but the videos will say "this file is not supported" or "this video can't be played" when you play these iTunes movies/TV shows on the Surface RT tablet.
In order to play iTunes video files on Microsoft Surface RT, you have to remove DRM from iTunes movies and convert iTunes M4V files to Surface RT compatible video formats(MP4 with H.264 video codec is highly recommended). To get the work done, a DRM Removal software is needed. If you're looking for ease-to-use, just check out Pavtube's ChewTune, which is an intuitive and stable DRM converter to help you remove DRM protection from iTunes, Amazon, Zune, BBC iPlayer, Napster, Blockbuster, etc. and convert videos to all popular video formats like MP4, MOV, MKV, WMV, AVI, FLV, etc. for playing and sharing anywhere you like. Meanwhile the playback of the converted videos is as decent as possible as original. The equivalent Mac version is the ChewTune Mac, which can convert and transfer iTunes movies to Surface RT on Mac OS X. Free download the right version and enjoy your iTunes M4V movies on Microsoft Surface RT without any hassle!
Download iTunes to Surface RT Converter:
Convert, Transfer and Play iTunes movies on Surface RT
The quick start guide below uses ChewTune Windows screenshots. The way to encoding iTunes M4V to Surface on Mac is almost the same. Just make sure you get the right version according to your computer operating system.
Step 1: Add iTunes movies to the software. Launch the DRM converter and click "Add Video" "Add Folder" to load the iTunes video files to the program for converting. You can also simply drag and drop media files to the source pane to add. Batch conversion is supported so that you can add multiple files.
Step 2: Choose the output video format and output folder. Click "Format" bar and move mouse to "Windows" column, you can easily find the profile of "Microsoft Surface Windows RT H.264 Video (*.mp4)". The output videos could fit on Surface RT or Pro perfectly.
If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish. For watching videos on the Windows RT based Surface Tablet, 720p with 1500~2500kbps is just all right. I found that bitrate higher results in big file size, and lower visible quality loss.
Step 3: After above steps, just click "Convert" to start removing iTunes DRM protection and converting iTunes M4V to Microsoft Surface RT MP4 videos.
Once the process completes, download and transfer the DRM-free iTunes videos to your Surface RT Tablet via USB cable. Then you are free to enjoy and watch iTunes movies on Microsoft Surface RT as you like.
And yes, this workaround works with Windows 8 as well, of course. Click here to get known the basic tips for watching movies on Microsoft Surface RT.
Related Articles:
How to put/move DVD movie to Microsoft Surface RT
Copy Blu-ray ISO image file to Microsoft Surface RT
Sync Digital Copy movies to Microsoft Surface RT
Watch Flash FLV/F4V Videos on Microsoft Surface RT Tablet
Surface RT Review: Convert 1080p/720p Videos to Surface RT & Pro
How to transfer Tivo files to Microsoft Surface RT
6 Essential Apps for New Windows Surface RT and Pro Owners
To save your money, you can view Pavtube special offer column:
ByteCopy($42) + Blu-ray Video Converter Ultimate($65) = Only $80, Save $27
ByteCopy for Mac($42) + iMedia Converter for Mac($65) = Only $80, Save $27
ChewTune ($29) + Blu-ray Video Converter Ultimate($65) = Only $75, Save $19
ChewTune for Mac($29) + iMedia Converter for Mac($65) = Only $75, Save $19
ChewTune($29) + ByteCopy($42) = Only $54, Save $17
ChewTune for Mac($29) + ByteCopy for Mac($42) = Only $54, Save $17
ByteCopy($42) + Video Converter($35) = Only $60, Save $17
