bdewitt82
So I got Streets & Trips 2013 installed on my Surface Pro but when I plug the GPS dongle in (Navigation GPS 168) I don't get an audible new hardware found alert or pop up or anything. The dongle lights up so I know it's working but S&T will just tell me there's no GPS device installed if I try to configure it.
I tried plugging it into my home desktop (also running Windows 8) and I get the new hardware found audible alert and pop up window. It also shows up in the Device Manager so I'm sure the dongle itself is fine.
When it's in the Surface Pro, it can only be found in the Device Manager if I choose "Show hidden devices" in the View menu but I'm not sure why it's hidden. I've tried manually updating the drivers to the ones found on the install disc and that didn't work nor did any of the suggestions in the Microsoft support article 894511 entitled "Solve problems with Pharos iGPS 500 device and the Navation GPS 168 devices in Streets and Trips or in MapPoint".
Anybody have any other ideas? Just to make sure it wasn't a setting in my Surface Pro, I did a complete restore to factory settings and wiped out all of my data, apps, and settings and it still did the same thing. Any help would be greatly appreciated...
