Surface Pro for OpenGL and Unity Development
michael075i
Hello, i would like to buy a surface pro device for developing opengl and unity when i am mobile. In general i am programing in C/C++ and Java via Visual Studio 2013 and Eclipse. So my choice is one of the following two devices:
1. Surface Pro 3 i5/128GB/4GB RAM
2. Surface Pro 4 i5/128GB/4GB RAM
Therefore i have the following questions:
1. Is it in general possible to develop OpenGL onto a surface pro device ?
2. If YES, which one should i buy ?
3. What OpenGL versions do the two Surfaces provide ?
4. How much time does the compile process need?
Thank you in advance for helps
Greetings
Mike
Thank you for the your reply, but i don't want to buy a laptop cause i have one. But on travel i want to have a small device,
so i thought about the surface pro. I will check this link you posted.
