Hello,
I have bought a Surface Pro 1 about 6 months ago because it seemed like a nice device. After using it for a while it's actually ok even though it sometimes makes me very annoyed. The biggest problem I'm having is connecting the charger to the device.
Sometimes I can connect the charger without any problems, but at other times (sometimes while in class, I think you can imagine how annoying this may be), I can try connecting the connector like 30 times and the device will keep saying "Connected, not charging". Eventually I can get it to charge (sometimes by moving the charger a bit from side to side) - look at the video a bit lower - .
I don't know what the issue might be, sometimes I'm thinking it might be the device itself because the charger sometimes doesn't seem properly connected.
But it might also be a software issue because I'm having this a lot of times when the device has recently been used so then it's still a little hot.
Here's a video where I can get the device to charge after moving the charger a bit (I got lucky to get it to charge this fast tbh):
This would be a situation where the device would say it's actually connected, but it just won't charge (until where the light lights up).
I hope someone here can confirm this being an issue, or possibly have a solution for this? I expected a little more quality from a device that cost me over 700 euros. Thank you.
