Nevvermind
- Joined
- Sep 20, 2014
- Messages
- 7
- Points
- 1
Hello,
has anyone of you noticed the sound problem that probably every surface has?
I have two surfaces and the problems appears on both. Here is how it comes up:
1. plug in headphones or speakers
2. play a sound/song whatever
3. stop it. Make sure no other sound is present (e.g. the sound of double clicking or a warning sound)
4. after a while a constant "bum bum bum bum" will appear on the headphones/speakers until you play another sound
This does not happen with the internal speakers, only when you plug speakers/headphones in. Can anyone confirm that for me?
I tested it with this
http://www.amazon.com/Beyerdynamic-70-Over-Headphone-Black/dp/B005EEOTFY/ref=sr_1_1?ie=UTF8&qid=1411242424&sr=8-1&keywords=t 70
and this
http://www.amazon.com/Logitech-X-530-5-1-Speaker-System/dp/B0002WPSCG/ref=sr_1_5?ie=UTF8&qid=1411242479&sr=8-5&keywords=logitech sound
and some inears. I also reinstalled windows. I tried everything but it appears on both surfaces - no matter what I do.
and this
