Hi
Windows 10 -fully updated
This issue is most annoying. When I start or restart, all the icons are present. After a short time, they disappear (not ALL of them, but about 90% of them. The hover text still works OK and is the only way (other than my memory) that I can use this menu to start applications. I will need to relocate these shortcuts to a folder on the DeskTop if I can't find a solution.
I can not identify anything that causes the icons to disappear after start up, I can use my Firefox browser and/or Thunderbird email applications after start up and one time the icons will still be there another time doing exactly the same and they will have disappeared.
I have tried one or two supposed solutions found via a Google search but none have had even the slightest effect.
I can't find any information in this forum using a variety of search terms.
I know I am not the only one to have this issue going by those Google searches I mentioned, and so I am surprised that there doesn't seem to be mentions of this problem here.
Has anyone here had this issue, know of a fix, know if MS is aware of it etc .........
