robrappucni
I understand the charger's light stays on whenever it's connected. Mine wasn't so I kept re positioning it. Soon after, I discovered the connection points on the charger were burnt. I got a new charger, cleaned all contact points on the Surface with alcohol, and plugged in the new charger. The light came on. I looked at it about an hour later and the light was off again. Is this normal?
Sometimes the battery goes dead after very little use and I'm thinking it's related to the charge light issue.
Anyone have an answer? Thanks
