surface book to 4k monitor
dyc2017
so i have my surface hooked up to my 4k monitor and using the monitor as the only active display....it looks fine for the most part, but i noticed the at the borders its a bit cut off...is there a way to fix that?
also, my sound isn;t working...well, it works if the source is from the surface book, but if i try to make the sound from the PC come out of the TV, it doesnt work...says another application is using it....
my TV is set up to a sound bar via hdmi arc.....and the surface book is connected to the TV via active miniDP to hdmi 2.0 connector.
chekhonte
Check your settings on your TV for something called Just Scan and set it to that. It's probably in the aspect ratio settings.
