Surface book 1 and ultrawide 34' curved monitor POSSIBLE?
dfloresgonz
Surface Book
Hello friends
I'm planning on buying a 34 inch Ultrawide 3440x1440 Curved Samsung monitor, I want to know if my surface will keep up with this monitor, resolution wise.
I'm not into gaming just working with a lot of windows I'm a programmer.
Thanks in advance.
I use one with my Pro X just fine, the SB should have no issues with it...
It's resolution 2880 x 1920 (pro X) the monitor I guess cannot be used with 3440x1440 right?
Same with SB max at 3000x2000
I extend the monitor - so my Pro X is driving both its internal monitor and the 3440x1440 QHD monitor...
y4m0W1sWmDd4JDlkEDV-1LcDZp_KeuQecfqyP5042aUJFw6ATO3kZaQCBi5EbqBkpmGsUAkQzT4NZSuudDBMokAh27KekIzfQoOz8vydntGVlkWlNSCbEC-04mGJtnFhSnzKvN0-dw4uR96mau0qyaQDdI27KazRyuJS7LsXaLk8iRB_eG5M_wJxWZlXGLL5uga
Great, but the monitor is at its maximum resolution? or at the pros' max resolution?
btw nice setup :)
And what port is used to connect? display Port? will I need an adapter? a surface dock will be better perhaps?
This are the specs I hope it can run really well
