I thought I would summarize the experiences and testing I have done surrounding the wireless connectivity issues in the SP3.
1. Driver dated 4/24/14: Version 15.68.3036.67 for the Marvell AVASTAR Wireless chip
At this point I have 2 open cases with Microsoft Support pressing for an acknowledgement of the issue and if they intend a new patch on the next super Tuesday.
- a. Relatively stable driver, 72bps connections to 2.4Ghz wireless while on line AC power.
- b. if the SP3 goes to sleep, the Bluetooth and wireless devices will be gone when you ask the SP3 to wake up.
- c. The sleep does not have to be deep
- d. This symptom appears about 70% of the time on sleeping
- e. If you ask for a driver update (From Devices -> Driver -> update driver) this is shown to be the best available driver
- a. It seems to have fixed the devices being visible on wake up. In that respect it is more reliable
- b. The Wifi connectivity, even though the device is there, is very unreliable.
- i. When the device is on battery, the wakeup from sleep will result in a widely varying set of behaviors, very slow wifi speeds, making it virtually useless
- 1. Cycling the wifi on and off will sometimes and randomly restore connectivity somewhat.
- 2. 2.4 vs. 5 Ghz does not seem to matter much
- 3. Rebooting, and deep power cycling (volume up and power shutdown) sometimes helps
- ii. When the device is on line AC and you power up and stay on line, it is a very stable environment.
