SomeoneOnLine
So I got my brand new Surface 3 (atom) 128GB that came with Win10 b.10240 and let it do all its updates includeing updating it to win10 b.1511 and loaded on all my apps and got it working just the way I wanted it working.....for the most part. Thats when I noticed that the screen was crazy bright and wouldn't let me change the brightness level no matter what I did. Started googleing and came across a article that said to load the generic vga drivers then change brightness levels then switch back to Intel HD Graphics. Well that is the problem. When ever I try to switch the driver it throws an error "This operation requires and interactive window station." Which may be related to the fact that I at one point may have accidentally installed the wrong Intel HD Drivers for the Pro 3 even though I have the Atom version (non-pro). So Im thinking that when I try to load the Intel HD drivers its trying to load the wrong one. Im trying to avoid doing a reset if I dont have to since it took most all day to get the damn thing loaded up with all my apps etc..
My thinking is if I can download just the correct intel hd drivers from wherever for the surface 3 that might help.
Well I found "Surface3_WiFi_Win10_151109_1.zip" and extracted the Graphics drivers and those give the same error. WTF.
Any help is appreciated.
~SOL
~SOL
