Stream Blu-ray ISO movies to Surface RT/Pro for playback smoothly
PavtubeVideo
So you’ve gotten Microsoft Surface Pro/RT tablet and feel like to putting movies to the new Windows 8 slab. Now the question is, your movies are backed up in ISO, which is way too big for the Surface Pro/RT tab to play with- how to compress the Blu-ray ISO backups to Microsoft Surface Pro/RT? Now with Pavtube Blu-ray Ripper, encoding movies for Surface RT is just as easy. The app compresses Blu-ray and DVD ISO to 1-2GB while converting 1080p HD movie to Microsoft Surface Pro/RT friendly format.
How to compress/put Blu-ray ISO for Microsoft Surface Pro/RT Playback on Mac:
1. Run Pavtube Blu-ray Ripper, click “ISO/IFO” folder to import Blu-ray ISO.
2. Select main title from file list and then preferred language in “Subtitles” and “Audio” box.
3. Click “Format” bar and select "Windows > Microsoft Surface Windows RT H.264 Video (*.mp4)" format.
4. Click “Convert” to convert Blu-ray ISO for Microsoft Surface Pro/RT. When conversion completes click the "Open" button to find the converted .mp4 movie and transfer the movie to Microsoft Surface Pro/RT.
This Microsoft Surface Pro/RT Blu-ray converter can also
  • Convert DVD ISO to Microsoft Surface RT supported format;
  • Hack and rip Blu-ray to Microsoft Surface RT tablet;
  • Convert DVD to Amazon Microsoft Surface RT for playback;
  • Rip DVD and Blu-ray to MKV, AVI, MOV, WMV, VOB, etc.
  • Compress Blu-ray and DVD to Galaxy Tab, iPad, Playbook, Nook tablet,etc
Remove DRM from iTunes M4V and Sync iTunes library to Surface RT and Pro
This article will show you how to get music, movies or TV-shows purchased from iTunes to Microsoft Surface RT for smoothly playing.
Q: I just bought a new Surface tablet and I am wondering if I could play music files I purchased on iTunes on my Surface RT? I have searched around the internet but I haven't got a specific answer to this question. Besides, the movies and TV-shows I have purchased on iTunes will be playable on my Surface RT?
A: Before answering your question, keep in mind that the Windows RT based Surface tablet can not play any iTunes purchases with Apple Digital Rights Management (FairPlay DRM). However, all iTunes songs (at least in the US) will be DRM-free in steps since April 7, 2009. From my experience, if the song isn't copy protected it should play. For the little copyrighted iTunes songs, in .m4p format, you can upgrade these songs to DRM-free files for US$0.30/song or use DRM removal software to strip DRM from them free of charge.
For iTunes videos, if they are video podcasts from iTunes, you can play them on your Surface RT without any problem. But if they are Movies, TV-shows or Music videos which you purchased directly through iTunes store, they are all with DRM protection. DRM can not stop you transferring iTunes video purchases to Surface RT, but the videos will say "this file is not supported" or "this video can't be played" when you play these iTunes movies/TV shows on the Surface RT tablet.
In order to play iTunes video files on Microsoft Surface RT, you have to remove DRM from iTunes movies and convert iTunes M4V files to Surface RT compatible video formats(MP4 with H.264 video codec is highly recommended). To get the work done, a DRM Removal software is needed. If you're looking for ease-to-use, just check out Pavtube's ChewTune, which is an intuitive and stable DRM converter to help you remove DRM protection from iTunes, Amazon, Zune, BBC iPlayer, Napster, Blockbuster, etc. and convert videos to all popular video formats like MP4, MOV, MKV, WMV, AVI, FLV, etc. for playing and sharing anywhere you like. Meanwhile the playback of the converted videos is as decent as possible as original. The equivalent Mac version is the ChewTune Mac, which can convert and transfer iTunes movies to Surface RT on Mac OS X. Free download the right version and enjoy your iTunes M4V movies on Microsoft Surface RT without any hassle!
Download iTunes to Surface RT Converter:
Convert, Transfer and Play iTunes movies on Surface RT
The quick start guide below uses ChewTune Windows screenshots. The way to encoding iTunes M4V to Surface on Mac is almost the same. Just make sure you get the right version according to your computer operating system.
Step 1: Add iTunes movies to the software. Launch the DRM converter and click "Add Video" "Add Folder" to load the iTunes video files to the program for converting. You can also simply drag and drop media files to the source pane to add. Batch conversion is supported so that you can add multiple files.
Step 2: Choose the output video format and output folder. Click "Format" bar and move mouse to "Windows" column, you can easily find the profile of "Microsoft Surface Windows RT H.264 Video (*.mp4)". The output videos could fit on Surface RT or Pro perfectly.
If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish. For watching videos on the Windows RT based Surface Tablet, 720p with 1500~2500kbps is just all right. I found that bitrate higher results in big file size, and lower visible quality loss.
Step 3: After above steps, just click "Convert" to start removing iTunes DRM protection and converting iTunes M4V to Microsoft Surface RT MP4 videos.
Once the process completes, download and transfer the DRM-free iTunes videos to your Surface RT Tablet via USB cable. Then you are free to enjoy and watch iTunes movies on Microsoft Surface RT as you like.
And yes, this workaround works with Windows 8 as well, of course. Click here to get known the basic tips for watching movies on Microsoft Surface RT.
Related Articles:
How to put/move DVD movie to Microsoft Surface RT
Sync Digital Copy movies to Microsoft Surface RT
Watch Flash FLV/F4V Videos on Microsoft Surface RT Tablet
Surface RT Review: Convert 1080p/720p Videos to Surface RT & Pro
How to transfer Tivo files to Microsoft Surface RT
6 Essential Apps for New Windows Surface RT and Pro Owners
To save your money, you can view Pavtube special offer column:
ByteCopy($42) + Blu-ray Video Converter Ultimate($65) = Only $80, Save $27
ByteCopy for Mac($42) + iMedia Converter for Mac($65) = Only $80, Save $27
ChewTune ($29) + Blu-ray Video Converter Ultimate($65) = Only $75, Save $19
ChewTune for Mac($29) + iMedia Converter for Mac($65) = Only $75, Save $19
ChewTune($29) + ByteCopy($42) = Only $54, Save $17
ChewTune for Mac($29) + ByteCopy for Mac($42) = Only $54, Save $17
ByteCopy($42) + Video Converter($35) = Only $60, Save $17
