Surface User
- Joined
- Mar 16, 2015
- Messages
- 20
- Points
- 1
I have just bought a used Surface Pro that is restored back to Windows 8 and then updated to Win 8.1 again, so i have not saved anything to the Surface Pro and have not made any partitions myself.
I think it looks as i have a lot of partitions that is made by Windows/Surface?
Also i think it uses a lot of disc space from the hard drive. I have a 128 GB SSD and it says that full capacity is 109 GB and that 19,6 GB is used from those 109 GB. Does this sound normal?
The partitions i have is:
1. Recovery partition (800 MB)
2. EFI-partition (200 MB)
3. Recovery partition (450 MB)
4. Recovery partition (350 MB)
5. Recovery partition (7,62 GB)
6. Windows C:, primary partition (109,74 GB)
And obviously the only partition that has a letter assigned to it is the C: partition.
So my question is does this look normal, if not how should it be? And is there something here i can delete or arrange to fewer partitions, isn't it enough with one recovery partition, not four of them? I just think it looks as a lot of recovery partitions. These partitions were there after the restore.
I would really appreciate some input on this matter. Thanks.
