Solved Screen flicker when using Surface 3 PRO on battery mode
dicks
I have a fully patched and current Win10 (Release Preview) Surface 3 PRO.
Recently I noticed an annoying screen flicker when using the device on battery (in idle). I downloaded and installed the latest Intel driver (20.19.15.4703) from and the issue with screen flicker was gone!!!!
Just in case others have the same issue, I thought I would post this.
Thank you for sharing this. I have not experienced. but I'm glad you found a solution.
