SB2 low FPS during light gaming when connected to AC
FT121
Surface Book
Hello everyone,
I got a SB2 13.5 a few weeks back, I just wanted to use it for casual gaming (Rocket League mainly) but I'm having some issues that I know for sure are not normal.
After a while I play (like 10 min) the FPS start to drop dramatically first to 30 than to 10. I checked the GPU temperature and it was like 40 C in gaming, the CPU instead is being weird. When I checked what was happening I couldnt figure it out (using Intel XTU), temperatures dont seem to rise too much and I couldnt see any constant throttling on the power, but also I'm not exactly sure about what to look for.
I tried putting the lowest power setting possible but it doesnt change anything. The only solution I fould, and it might be indicative of the cause of this for someone, is that as soon as I unplug the computer the frame rates jumps back to 60 in a few seconds and stays perfect indefinitely.
Does anyone have some suggestions of what I should try to do to make it work? I know for sure that it's not my unit that is defective because I had it replaced for another issue and the one I had before was doing the same exact thing....
Thanks for any help you may provide!!!
Do you have some power-saving measures set to enable when you plug in?
That's all I can think of, if your slider is on "Best performance" and you're plugged in you really should be fine.
FT121 - Let me ask what might be a redundant question here - Are you using an external monitor, or the Surface Screen?
