Like a lot of people I have multiple computers. Recently bought a Surface Pro 3. Trying to use it more and more. I would like to think the Surface Pro is a tabletesk laptop that should work the same. After all my laptop and Surface both have Windows 8 on it. Would think they are the same. Notice one issue I'm not sure how to resolve. Right click in IE. Two scenarios:
Thanks for your input/thoughts.
Steve
- I have a web app monitoring solution that runs fine on my Win 8 laptop and has right click context menus to manage various items if you select a system. Right clicking on an item pulls up a menu of unique options. Works on the laptop, on the Surface right click shows some kind of small empty box (not the size of the pulldown) with no content in it. Does this with Metro or non Metro IE.
- I have an app Paprika. Recipe manager app. It allows you to pull up a website containing a recipe and select items to add as the name, then the picture, then the ingredients and the instructions. The way to add the picture is to right click on it and select copy. Works fine on my laptop, on the Surface doesn't do anything when I right click. This is a non metro app.
Steve
