Red boot up screen help
Crowns77
Surface pro stuck on red startup screen have tried these steps. Press the Power button and the Volume Up button at same time while you are starting the Surface Pro device. Set Trusted Platform Module (TPM) to enabled. Set Secure Boot Control to enabled. Press Install Default Secure Boot keys. Press Exit setup, and then save the changes. But I setup a password on accident and will not boot past it
