Recommendation of SP3 12v car charger?
HAWKY
Hello,
I've done a little research, however cigarette lighter car chargers are limited for the SP3! Does anyone have one? Could you recommend or provide a link to one? There are a couple cheap ones on ebay... however for an expensive i7 256GB SP3, i don't wish to break it!
Regards.
Hello,
Regards.
Hi Hawky, welcome to the forum.
Honestly, you'd be better off with an inverter like this- http://amzn.com/B004MDXS0U, or this- http://amzn.com/B00VMRHE7C. In this way you could not only power your SP3, but basically anything that plugs into the wall.
There ARE some 12V SP3 chargers out there (http://www.mikegyver.com/Mikegyver-...icrosoft-surface-adapter-with-car-adapter-kit) but for the money, you're better of to buy something that can power a LOT of things from your vehicle, and not just one.
Thanks for the welcoming!
That sounds quite reasonable, im going on a week long road trip and require the sp3 for it. Thanks for the response mate, really do appreciate it!
I found a cheap one on Amazon but haven't used it yet. I'd send a link but right at this second Amazon can't show my order history.
Randy
Edit - the power inverter idea is a great idea for a road trip!
