quick help, onscreen keyboard fault?
stustaff
am I going mad?
with on screen keyboard showing I can scroll but can't tap/left click anything? eg I can't press the x to close a window or press to select a different text box on a form etc.
I'm almost certain I used to be able to! bug or have I changed a setting somewhere?
S
stustaff
ok confirmed it is an issue! I have it after every fresh restart until I quit the 'touch keyboard and handwriting panel' process.
if I use task manager to quit that then click on keyboard iconto bring it back it restarts and the issue is gone
S
stustaff
thanks
I can replicate this issue now should I contact MS or is it not worth it?
if so howdo I contact them with something like this?
jnjroach
Administrator
thanks
I'm unable to replicate...can you tell us exactly what apps/browsers this is happening in, are you in tablet or desktop mode and have you installed any apps like AHK.
S
stustaff
It's happening in everything.
Switch sp3 on. Unlock. Open file browser or edge or Firefox or anything.
Bring up keyboard manually or auto I can type but top half of screen I can scroll as normal but can't tap/left click on anything.
If I close the process keyboard disappears. Press on icon to get it back and it works as normal.!?
