power button shuts down
kuodachrome
Hi all,
Randomly, my SP4 will now shutdown when I press the power button. In the past, it would enter sleep mode. Any ideas?
Also, I used to press the power button + volume up buttons at the same time to login (alternative option is control + alt + delete) but it randomly changed to power button + volume down. What's happening?
Hi all,
Navigate here - Control Panel\All Control Panel Items\Power Options\System Settings
What are your settings?
Thanks Jeff! I'm not sure what to say, but as soon as I read your post, I tried the power button and it was fixed... before changing anything. Only thing I did in the mean time was shut down and turn it back on. I did check the settings and the power button is set to sleep for all options. Appreciate your help!
