Hey guys.
I am sorry if I my post is going to overlap with an older one, but I could not find a specific one through the threads. I have the SP3 for some time now and I do use it on the go. So far, the battery itself has been enough for me, but I have been looking into buying a power bank of some sorts. I did face some challenges though, as which one to buy, how much capacity should it have and what kind of power output do I actually need for my SP3. I am a bit concerned about buying one anyways, cause I do not want to damage my SP3, because I have used an unreliable or cheap powerbank, or because I have used the wrong V output.
I was thinking to buy a quality device that could support me if i am away from a socket for over a day or more, I believe that would mean at least one full charge of the SP3.
So if anyone of you guys is using such a thing and could share some experience and recommendations
Thanks.
PS. This is a list of the ones I have found myself, after some reading and digging around the web:
1) http://www.amazon.com/gp/product/B0...ue&ref_=ox_sc_sfl_title_1&smid=A3DNJ55ZGSMH7I
2) http://www.amazon.com/gp/product/B0...mini_detail?ie=UTF8&psc=1&smid=A2KUZVNQ9LP7N9
3) http://www.amazon.com/Anker-20000mA...=1446049564&sr=1-1&keywords=anker+astro+pro+2
4)http://www.amazon.com/Poweradd-Pilo..._UL160_SR160,160_&refRID=0ZM593X0W6JD5KFM93VS
5)http://www.amazon.com/gp/product/B0...e=as3&tag=abrodrea-20&linkId=CYRCL42TC2XLVARP
6)http://www.amazon.com/ChargeTech-Po...p/B00MVDV99U/ref=cm_cr_pr_product_top?ie=UTF8
7)Mikegyver 34.2AH Surface Pro 3 External Battery & Car Adapter
8)http://www.amazon.com/20000mAh-Mult...ref=sr_1_5?s=pc&ie=UTF8&qid=1429203290&sr=1-5
And I assume I would need a cable like this one:
http://www.amazon.com/Portable-Charging-Charger-Microsoft-Surface/dp/B00O6UCGS4
Thanks.
