Post Your SP3 Power/Battery/Charging Issues Here
I have to chime in here too! I was consistently getting around 8 hrs 30 mins or so on my SP3 with about 30% left. But after the last firmware update something happened. Now, after 4 hrs 30 mins, the system reports a battery level of 46%!!! My work pattern has not changed - OneDrive, Word, very little browsing, most notifications off. I have drained the battery and have charged back up to recalibrate. Any ideas?
Edit: I have the i5, 4GB RAM, 128GB version.
Edit 2: I just ran the battery report and I notice that from the 21rd of Jan, this year, the battery performance dropped from 8 hr 25 mins to 5 hr 40 mins (as on the 26th of Jan). It could be that I am not reading the report correctly, but this seemingly bears out my experience in my daily usage.
Edit 3: I just reduced the screen brightness - on battery - down from 40% to 38%. Let's see if this makes even an iota of difference.
I'm going to run on battery today to see what my battery usage is like. I haven't confirmed, but I feel that the battery life has declined since the last few updates. I was able to use it for a solid 7-8 hours at work (screen off, using USB dock). Will run it today and report back.
i5, 4gb/128GB
8:50AM EST started using the battery.
i5, 4gb/128GB
Yeah...that would be cool...could you please post back here your findings? I have now been on my SP3 for 6 hrs 12 mins (I got this from my 1520, which I took off the charger at exactly the same time as the SP3) and I am 29%. Not good!
Edit: What's odd is that (1) in every other way the SP3 is performing exceedingly well and (2) not many people here are reporting any adverse battery-life-related issues after the most recent updates.
Here's a capture of my battery report from today. Right now it's down to 32% and seems to drop faster than it had before. So I'm pushing 7 hours so far.
3:56pm @32%
[Edit] 4:18PM @ 28%
Seems like it's dropping faster when the battery is low.
This is my battery report - not the whole of today but still mid-day from start. Notice the very sharp drop between 12:05PM and 12:43PM. The percentage drop from 60% to 48%!!!! And, I was doing nothing that I was not doing earlier (or for that matter later) in the day!!! I wonder what accounts for this sharp drop!
My SP3 will not charge with AC adapter.
I gave the port a good clean, even bought another (expensive) SP3 charger, tried charging my SP3 at JBHifi, and desperately tried to squash the port, all to no avail. I can't even get the LED to flicker anymore.
The device is out of warranty so Microsoft suggested a replacement for $799 AUD. I paid $1000 for the device a year and a half ago. An IT repair shop said they can replace a charger port for $399, I may go down this path and sell it once I've completed this month's project.
The work around I have had to use is a 12v car charger ($40) and a 7.5 amp 12v-240v inverter ($50). I assume it doesn't 'talk' to the device in any way - just pushes power into it. It is cumbersome but at least I can use my SP3 again. I would like to know if I can make the AC charger function the same way.
I'm looking very closely at the new Surfaces for the same fault as some use the same connector type.
