I thought I would start posting my thoughts on the Pro 2
Unboxing experience - First Class (just like Gen 1)
Setup - If you have set up a Windows 8 or 8.1 machine it works the same (very quick). What is new, the Syncing of your Apps and Settings from your other 8.1 Machine is seamless and quick. Start Screen Sync works well, even moving between a 720 RT to the 1080 Pro.
The Pro is chunky especially coming from the Gen 1 RT and it does get warm around the Edge Venting. This thing is very fast, blows my IvyBridge Samsung Ultrabook away with similar specs (Except the UB was a Hybrid Drive).
Touch is responsive and Digitizer is what we've come to expect from Wacom, Inking in OneNote is very good, no lag with very good Palm Rejection. I'm getting really good edge accuracy without the jitters we come to expect.
So far I've uninstalled the version of Office and installed Office 2013 Pro Plus and ran updates, joined it to the Corporate Domain and Configured Outlook and have finished Syncing with SkyDrive and OneNote. I will start battery tests shortly, it came OOB with around 50% battery I ran it down to about 15% with installs and updates in around 2 hours (Balanced Power Scheme and adaptive brightness with WiFi and Bluetooth), should also mentioned I did one 45 minute Lync Conference Call as well and that tends to use up battery very quickly.
The Type Cover 2 is amazing, the cursor bounce is non-existent the Trackpad buttons will take some getting use to. Touch Cover 2 is also I great upgrade, works much better than Touch 1 and has Auto-Complete like the OSK does. I've been typing this paragraph with the Touch 2 and I'm actually typing faster on it than Type 2.
So far this is a great machine and I would recommend it to anyone looking for an ultraportable hybrid that has power and an active digitizer.
I will be added more to this as I observe more. I'm headed to the Midnight launch in Bellevue tonight if there are any Western Washington members in the area. I will be buying 3 of the DP to HDMI Adapters to tie us over till we can get the Docking Stations.
