Solved onscreen keyboard not popping up for GT Racer 2
Captpt
I just downloaded GT Racer 2 from the Store and the first thing I need to do is put in whatever name I choose for my driver but the onscreen keyboard will not pop up??
Any one else run into this issue???
bvone21
Yeah I did...do you have type cover plugged in and flipped back? I think I recall that if I removed the type cover and restarted GT Racer 2 then it was fine.
...or maybe I just used the type cover to enter it...I can't exactly remember the resolution but I know that I ran into this issue because it prompts you for a name at launch...
C
Captpt
I don't have a type cover or Bluetooth keyboard, I'm strictly a on-screen keyboard SP3 user..
