Mini Display port to HDMI male-male cable from dock
Hello all!
I am getting a SP3 with dock from work soon, pretty excited!
I have a question though. I have my really nice 1080p monitor at home I want to connect with the dock. I have a free standing desk and therefore hate cable clutter.
I want to connect my dock and monitor using a short male-male MDP to HDMI. However, I have heard that it has to be active, doesn't have to be active, and what is active. This all in all has left me a little confused.
Looks like this, more or less
Any thoughts on what to get? Also, if you have recommendations for a 0.5 meter cable, that would be awesome!
Thanks,
Gregers
My idea was to have the monitor just behind (above) the dock, so the two screens are more or less aligned. I'll see when I get the setup done how much I actually need. I'm more concerned about the whole "active" thing, is there anything to that?
The cable linked supports up to 4k video which is all an SP3 can push.. Active components are likely enclosed in the large connector head. To me, Active just means it's not a straight piece of wire but has components to smooth/boost the signal. this will clear it up :)
http://www.cablechick.com.au/blog/active-vs-passive-cables-switches-splitters/
No? It depends on your use case but unless you wanted to do multiple HDMI monitors a simple passive aggressive :) err passive/active (non-powered by external means or without requiring an adapter/converter) cable is the right choice.
