manage wireless roaming
CharlieH
I have multiple access points in my home. How do I get my surface 4 to connect to the nearest/strongest access point? Normally there's an adapter setting that regulates a threshold on when to change to a stronger access point....typically called 'roaming aggressiveness'. I can't find anything like that in the settings for my Marvell Avastar adapter.
Changed the title as the "How To" Prefix is reserved for tutorials.
As for the your question - the Marvell doesn't have much around Management. Does your APs all use the same SSID Name?
I've configured my network both ways...First I used different SSID names for the APs. The wireless adapter would connect with one and stay connected with a faint signal even as I moved nearer to an AP with a stronger signal. Then I tried having all APs use the same SSID name. I also made sure that all APs used the same security, WPA2. I got the same result. The Surface 4 wireless stays connected to an AP as long as there's some signal.
Does the Marvell adapter in the Surface 4 have any logic to trigger switching APs? I can't find a setting that manages that. I think that's a real problem. Seems like most other adapters have a setting where the roaming tolerance can be managed. My only solution is to use different SSID names and manually change to the AP with the strongest signal as I move around the house.
Do you suggest I use the same SSID names for each AP or should I use different ones?
Typically in a business setting I configure all with the same SSID and do I site survey so there isn't much overlap...
[QUOTE = "CharlieH, poste: 165548, membre: 23689"] J'ai plusieurs points d'accès chez moi. Comment puis-je connecter ma surface 4 au point d'accès le plus proche / le plus fort? Normalement, il existe un paramètre d'adaptateur qui règle un seuil pour passer à un point d'accès plus puissant .... généralement appelé «agressivité itinérante». Je ne trouve rien de tel dans les paramètres de mon adaptateur Marvell Avastar. [/ QUOTE]
Hello, i test USB Key wifi : Linksys AE6000 with "roaming sensitivity" option
