PavtubeVideo
Featuring a 10.6-inch ClearType HD display, Microsoft Surface RT & Pro Tablet can bring you brand-new visual perception. However, if you have a glance on the main spec of Microsoft surface Tablets, it's easy to find that Windows 8 Tablet video format is limited as other tablets. Thus, if you wanna watch MKV 1080p/720p movies on your Surface Pro Tablet, first you need to convert MKV to Microsoft Surface Tablet playable format like MP4, or WMV and then transfer them to your Tablet for playback.
Here is a guide about how to transfer MKV movies to Surface Pro with Mac OS X computer.
Download the Microsoft Surface Video Converter:
Free Trial Video Converter for Mac
How to Convert MKV to Surface Pro supported video files on Mac
1. Install and Launch Mac MKV to Surface Pro converter, click "Add Video" icon to import source Video files.
2. Click "Format" bar, follow "Common Video> H.264 Video (*.mp4)". If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish.
3. Start the conversion.
4. Transfer the result videos to your Surface Windows Tablet via USB cable.
So there you have it. Pretty simple! In this way, you can easily and fast enjoy 1080p/720p MKV files on Microsoft Surface Pro Windows Tablet without problems.
P.S. If you’re going to transfer Blu-ray/DVD movies and HD videos to your Surface Tablet for playback, you can get Pavtube iMedia converter for Mac to achieve your goal.
