Limited WiFi and Bluetooth
vchaganti
I have been experiencing "limited" wifi issue and I have found that turning off the bluetooth radio fixes the issue immediately.
After I turn the bluetooth off and connect to wifi, I can turn the bluetooth radio back on and everything works fine.
The problem resurfaces if I have to wake up the system from sleep.
Has anyone seen this issue? Should I re-install the bluetooth drivers?
Try Setting your Wifi / BT radio to Hi_performande mode instead of battery mode it should resolve wake up issues :wink:
