Keyboard does not work when edge is opened
rap429
When I launch edge on pro 3 it locks up. neither keyboard or pen work. Keyboard still works if I switch apps so it is isolated to edge. Any fixes?
My suggestion would be to run CCleaner. If you haven't used it before make sure you uncheck cookies and maybe a few other things you don't want cleaned. It knows how to clean the cache from Edge and that may fix it
