Is touch cover for Surface Pro the same as for Surface RT
chrisb
I'm sure the answer to this question is Yes, but want to double check with others. Presumably the touch cover is the same for the Surface RT and Surface Pro? i.e. it will fit both devices?
Many thanks
Chris --
Arnold is right (as usual). The covers are interchangeable. I ordered a Type Cover to go with my Ladyfriend's Pro, when it arrives. It snaps right onto my RT and works fine. Actually, I kinda prefer the Touch Cover, but typing not one of my high-order skills.
Regards,
Russ
