PavtubeVideo
If you want to play DVD ISO/IFO movies on the Surface Tablets, you need to convert DVD ISO/IFO to Surface Tablet accepted videos on computer as your first move along with some help from third-party softwares. If you’re instersted in doing this likewise, check out the following tutorial, which mainly shows you the infomation about what software setup is, and how to rip DVD ISO/IFO movie to Surface Pro Tablet supported video format.
Most of you are likely familiar with the excellent Handbrake for ripping standard Def DVD ISO/IFOs, keep in mind that that program can’t rip copy-protected DVD ISO/IFOs without a third-party add-on, and it doesn’t have Surface-specific profiles. You may confused about choosing a suitable tool. If so, I recommend you try Pavtube DVD ISO/IFO Ripper . It is easy to use for editing and conversion and makes great quality copies of my DVD ISO/IFOs. To be honest, the DVD ISO/IFO to Microsoft Surface Converter can help you rip and convert all the DVD ISO/IFO image files. Besides, the audio/video synchronization is very good, the size of the subtitles too. Below is how.
How to Convert DVD ISO/IFO movies to Microsoft Surface Pro Tablet supported video formats
Note: The quick start guide below uses DVD ISO/IFO Ripper Windows screenshots. The way ripping DVD ISO/IFO movies for Surface Tablet is almost the same.
1. Add DVD ISO/IFO movies.
Once launch the DVD ISO/IFO Ripper for Microsoft Surface, click “DVD ISO/IFO icon” to load the DVD ISO/IFO videos.
2. Choose output format
Click “Format” bar, follow “Windows > Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)”. You can click “Settings” to change the video encoder, resolution, frame rate, etc. as you wish (Remember: bitrate higher results in big file size, and lower visible quality loss).
3. Start the conversion
Click “Convert” button to start to rip DVD ISO/IFO movies to h.264 MP4 videos for playback with Microsoft Surface Windows RT and Surface Windows 8 Pro. After the process, you can click “Open” button to locate the converted MP4 video files. Just transfer the video to Surface Windows 8 RT or Pro through cable.
In this way, you can watch DVD ISO/IFO movies on Microsoft Surface Pro Tablet and enjoy DVD ISO/IFO movies on the go!
