macmee
when I'm home on my desktop I like to put my surface into tablet mode and rest it flat on my desk. the problem is windows hello obviously cant see me in this position so I have to unlock with a pin. this can be very slow because you first have to swipe windows hello up and away, tap a very small button for pin, then type your pin in.
if I only had to do this once every 30 minutes or so that would be fine but I want to be able to use the device for. few minutes, turn the screen off to do more work on the desktop, then hop back on the surface for a few minutes.
Anyway I was wondering if there's a way I can tell windows to disable the lock screen for the next hour, or if I can get a easier way to unlock the device for when my face isn't visible to windows hello
