Fan start to spin when charging
warpdesign
Surface Book
Today, after a week or two of light use (which is quite nice), I had to charge my Surface Book, so I plugged in the cable and put the computer to sleep by pressing the power button.
A minute or two after that, the fans started to spin very fast. I touched the computer and noticed it was very hot.
The weird thing is that if I exit sleep mode, or if I unplug the charging coord the temperture goes down quickly so the fans stop spinning but the second I plug the charger and put it to sleep it gets hot again and triggers the fans.
I tried rebooting the computer but the problem was still there. I have no antivirus and no apps were running.
Also, that's with the stable Windows 10 release and every updates installed, I'm not running insider builds.
I had a big Windows cumulative update today so maybe that's what made the problem start (there was an update for the "Intel CSI2 Host Controller" among all updates) ?
Anyone noticed the same problem ?
yes, i have it to... everytime i plug the cable in the fans start to spin... have you found a solution?
Not yet :(
What Surface Book model do you have ?
Did you have this problem from the begining ? I'm not sure I had it before: I think I'd have noticed it.
I received a bunch of driver updates this week end, I'll see if it fixes the problem.
It could be windows defender scanning. I always plug the charger in first then hit the power button. If I do it power button then charger, it heats up quite quickly.
Had this problem with my SP 3 too and with my SB. No idea what causes it.
Sent from my SC-01F using Tapatalk
