External Hard Drive Problems
Beerz101
I bought a WD My Passport 3TB External Hard drive for school, when I try to use it it doesn't work at all. It will freeze and wont copy big files over but pdfs and word documents are fine. I tested the Hard Drive on my Surface Pro 2 and it works fine I can copy anything on to it. Any ideas?
Welcome to the forum
Is that one of the Passports that plugs into AC? If so it may need more power. If not you may need a powered USB HUB.
It's one that just plugs in to use no ac. I have also plugged in a friends 2 tb passport and it worked fine.
Some drive pull more power than that USB can output. You could try with the power plugged into your Surface.
@Beerz101
I had this problem about a year ago with a 2TB Passport drive and my Surface Pro 3.
I reformatted the drive ExFAT from that same SP3, and the problem went away.
Needless to say, I worried about the data for about a month after that, but have never had a problem. Now, my entire media library lives on it.
And I'm typing this on that same SP3 while playing music from the drive via iTunes right at the moment.
