blakeseven
- Joined
- Mar 25, 2014
- Messages
- 3
- Points
- 0
I've been struggling with dual monitors on my the Surface Pro 2. I am using two 24" ASUS Monitors that support Display port 1.1. I have both the EVGA hub and the Club 3 hub and the Microsoft Docking Station.. I was only able to get the club 3 to work. What I have found thru the help of Microsoft is that the surface will drive the Club 3 if and only if you have never connected the dock to your surface. Once the Dock is connected. The surface will install new firmware in the background to support the dock. This firmware breaks dual monitor support thru the Club 3. The only was to get it working again, is to reset the surface and plug the club 3 directly into the surface mini port.
I am told from 2 tech reps at Microsoft that this is the first they have heard about this and it will take a new firmware patch to correct this issue. They have moved my ticket up stream.
Has anyone else had this issue ?
