Connect to wireless screen
tcomte
Hi guys
I'm currently looking for a tab and i'm really interested in the Surface 3
It meets all my requirements and my needs, except for one point and I could not find an answer/explanation anywhere.
Is the Surface 3 able to connect to wireless display using miracast? I don't have a smart-tv but if i buy the wireless adapter from Microsoft, will i be able to connect to my tv using the surface 3 ? Is there any specifications for my tv (except of having an HDMI and USB port) ?
Thank you all for your answers :)
Yes, the Surface 3 supports Miracast....as long as the TV has an HDMI Port it should work.
If you're looking to get the Microsoft Wireless display adapter, all you need for your tv is an HDMI and USB port. Works pretty well actually, I recommend it.
