Compatible USB-C charger?
quarien
Hi,
I'm looking for third party USB-C charger with multiple fast charge ports to use it on the go.
I've bought something like this: Baseus BS-EU910 PPS Quick Charge 4.0 3.0 PD 3.0 Fast Charger USB Phone Charger and unfortunately there is a grounding issue and the touch screen glitches all the time.
I've plugged in to the random Lenovo usb-c charger ... and it works still fine - so luckily that's no the issue of my Surface Pro 7.
But back to the square one - can you recommend a charger similar to the Baseus one that will work properly with my device?
