Bluetooth problem
GegeNY
Hello,
I have a problem with bluetooth.
It happen quite a few times, the attached keyboard doesn't respond to any command, cannot type, and then the arc mouse doesn't do anything either, still have the cursor but I have to use the desktop keyboard to save my work.
Then I restart the surface and everything work again.
This is very annoying, do someone know about this problem?
Thank you for your help.
Perhaps 2.4 GHz interference. See if the same problem happens in another location - in a cafe, or hme or work, etc.
I use 5GHz for my connection.
Will try again updating, but I think I have all the updates already
We have 2 same Surfaces, only one has this problem.
Thank you for your answer.
Maybe try removing the device in Device Manager and let it reinstall the driver.
BTW how far apart are these several devices 2 Surfaces and the Partridge in a Bluetooth Pair Tree???
